I HAVE A NEWLY CONSTRUCTED HOME, I WANT TO INSTALL A BATHROOM IN AN ALREADY STUBBED OUT BASEMENT. TWO WATER SUPPLY LINES ARE LOCATED ABOVE WHERE BATHROOM WILL BE LOCATED. I CAN NOT DETERMINE WHICH IS HOT OR COLD LINE(CVPVC). HOW DO I PREPARE THE WATER SUPPLY LINES FOR A TAP IN FOR RUNNING BRANCH EXT. FOR SHOWER,TOILET, AND SINK. HOW DO I DRAIN THE SYSTEM TO PREVENT BACKFLOW. THIS IS A TRI-LEVEL HOME WITH WATER HEATER, HEATING/AC, AND GAS FURNACE. I CAN NOT DETERMINE WHERE TO SHUT OFF MAIN WATER DUE TO FINISHED WALL ON ONE SIDE OF LOCATION OF THE BATHROOM WHERE THE EXTENDING WATER SUPPLY LINE COME FROM. I WOULD APPRECIATE ANY ADVICE OR REFERRALS THAT YOU MIGHT HAVE. PLEASE RESPOND BY E-MAIL THANK YOU, MIFFED
