Re: low pressure problem with kitchen faucet
Posted by Marty on September 03, 19100 at 16:18:59:
In response to Re: low pressure problem with kitchen faucet
Remove the aerator at thre end of the kitchen spout. Some debris might have worked it's way through the lines and clogged the aerator screen.If that's ok, you may have to disassemble the faucet and check for any blockages at the cartridge(s).Finally, if that does not solve the problem, if you have shut-off valves under the sink to the kitchen faucet, you may have to check it anything is clogging these valves. Make sure you turn off the water first!!Check the aerator first, though. Good luck. Marty
Replies to this post
There are none. |
