Re: post tension slab and plumbing
Posted by hj on September 28, 1998 at 02:45:48:
In response to Re: post tension slab and plumbing
Usually the reason for the warning is to avoid damaging the cables. If the contractor has a good drawing of the system, or has it X-rayed first, then coring is usually okay. It is done in tenant improvements every day, with those caveats.
: Hi,
: We are buying a new home and frequently go out to the site to see the progress. We noticed that on the bottom florr, the post tension slab is poured over the spot where the toilet is supposed to go. Every other plan like ours has a stub where the toilet fits, except ours and 1 other. We wlaked into the other and noticed that the contractors had cored the slab to put in the plumbing for the toilet. Ours is still covered up (not cored). Is this legal to core? On the garage foundation there is a stamp that says "Post tension slab, do not cut or core". Do you have any advice for me.
: Thanks,
: Denise
Replies to this post
There are none.
