| Posted by Andy on September 01, 19100 at 11:52:25: | |
I believe that my T& P valve may be stuck in an open or partially open position. There is a faint sound of running water coming from the water heater and the drain pipe that leads from the valve The unit is made by Ruud and has a date of 1994 on it. There is some blurry cryptic test on the button on the valve, My thermostat is set at 140 - is this too hot and may be overpressurising the system? Or does the T & P What steps should I take to safely replace it? I have an expansion tank on the cold water inlet. Thanks for any advice anyone can offer. |
| There are none. |
