| Posted by hj on September 27, 1998 at 00:20:58: | |
| In response to Re: removing valve stems from shower H2O controls | |
If the stem turns continually without coming out, I would guess you have gone too far already. The housing that the stem screws into is what you should have removed, (at least in 90% of faucets), and the ones that are different are the ones that unscrewing the stem would remove it. : I'm in the middle of attempting to remove and replace the washers from a leaking bathtub faucet. : : Howard
| There are none. |
