| Posted by KT on August 25, 19100 at 12:19:12: | |
We have a leak from our second story tub enclosure that has now caused damage in our kitchen. The leak detection service has stated that they believe the leak occurred due to problems with the overflow drain. When we pulled the overflow drain apart, the pipe is 1.5 - 2 inches smaller than the cut-out in the tub and there is an offset foam ring around the pipe. Is this a normal installation process for an overflow drain? Thanks for the help! |
| There are none. |
