| Posted by hj on September 24, 1998 at 10:26:30: | |
| In response to Re: what is a wet vent ? | |
He should have run a vent pipe from the lower system up to the piping on the upper floor. The way it was done should work in your case, but in a different situation, flushing an upper toilet could cause the water in the lower toilet to either blow out of the bowl, or be sucked down the drain. Neither situation not being particularly desirable. : hi terry, : i am remodeling my basement - and putting in a bathroom (toilet, corner : thanks!
| There are none. |
