Re: Leaky shower
Posted by hj on September 24, 1998 at 10:19:40:
In response to Re: Leaky shower
The shower head does not have anything to do with the leak. Repair the mechanism behind the handle and the problem will be solved. BUT, either remove the bonnet nut carefully, or if it stuck, call a plumber, or you will have a two piece faucet and few plumbers know how to put it back together again.
: I have a Delta shower (single-valve handle) that is leaking. I don't know whether to replace the gasket in the shower head, or remove the handle apparatus and replace the handle fixture.
Replies to this post
There are none.
