Re: Installing Water Softener System
Posted by Brian on August 22, 19100 at 14:00:36:
In response to Re: Installing Water Softener System
: I want to install a water softening system. Is there an easy way to find the sewer drain? My laundry room is off the garage. I have a two story home.
You can run the drain line of the softener to any open drain such as a floor drain or laundry tub, etc. Check with local codes, if you have a septic system, you may not be able to run the drain to it. You must have a physical air gap between the drain line and the flood plane of the drain of 2.5 inches to prvent cross contamination of sewer water and drinking water. E-mail for more questions
Replies to this post
There are none.
