Re: case 3000 wall hung toilets
Posted by B. Silva on August 22, 19100 at 01:03:20:
In response to Re: case 3000 wall hung toilets
Chris,
It would be ALOT cheaper to go with new parts than to go with new toilets because these toilets have unique mounting, and it would cost a fortune to redo the framing and the carriers for new wall hung toilets. The case model 3000 uses the Model 50 ballcock which sells for $200.00 by Best Mfg. I know that the price sounds shocking, but it's way cheaper than new toilets, even floor mounted, back outlet ones. To find more info for Case toilets, go to www.plumbingworld.com and scroll all the way to the bottom and click on "To the world of 1,000's of other plumbing parts". Once there, you will see a long list of plumbing parts. They are listed in alphabetical order, so scroll down until you see "Case toilet parts". Click on it, and you'll see some parts for sale. If you're unsure of these parts, contact Briggs, they bought out Case and still make parts for the 3000. Hope this is of some help.
B. Silva
Replies to this post
There are none.
