Re: Okay, more info here........
Posted by More on August 20, 19100 at 20:59:07:
In response to Re: Okay, more info here........
: I have not done any work on my bathtub before, it must be leaking due to age, there are 2 handles for the water, hot/cold, then a thing to pull up for the shower, my only plumbing experiance to date was changing a bathroom sink faucet, which wasn't too hard really, so if anyone could just walk me through what to do to stop the leaking I would be very thankful, and I have no idea what brand the faucet is, looks old... See here..... The faucets have a handle that you turn which causes a screw thread to make the stem of the valve get closer or farther away from the valve seat. You need to turn off the water to the house, unscrew the valve stems and look at the rubber washers in the base, Those rubber washers have a brass screw in their center that you can remove, and pry out the washer, and go to the hardware store get a new washer, and re-assemble.
Replies to this post
There are none. |
