Re: copper hot water pipe joint leaking -help1
Posted by Terry Love on August 18, 19100 at 20:08:38:
In response to Re: copper hot water pipe joint leaking -help1
 : The elbow (?) joint on a copper pipe going up into my first : floor shower is leaking around the joint. Hot water line. : This is under floor (at basement ceiling, I can see it : and get to it easily). New work - three months old. I : need to seal it at least temporarily. I'm in a very rural : area. I have some Dap silicone rubber sealant. Will this : corrode the pipe? I also have some plumber's putty, some : joint compound, and I'm sure I have some epoxy somewhere. : Also some Liquid Nails/small projects. Will any of this : work? Try the epoxy for sealing pipes. And then replace the fitting later if you can. It would be a sad thing for it to blow apart when you're not home. Terry
Replies to this post
There are none. |
