| Posted by hj on August 17, 19100 at 00:14:10: | |
| In response to Re: what tool do I use to remove a bathtub drain? | |
The rust around the drain bothers me. About the only tubs that will rust that way are steel tubs, and when it happens, it usually means that the tub has rusted out around the drain and when you remove the drain you will find a larger hole than is supposed to be there. If that is the case when you remove the drain, you will just have to bust your budget and install a new tub. : I have a leak coming from somewhere around the bathtub drain. There is rust all around the drain on the surface : Thanks,
| There are none. |
