| Posted by John Morrissey on August 14, 19100 at 06:44:20: | |
I have recently installed a simple direct (immersion heater) hot water system in a bungalow type guest house. Everything works fine except that the hot water pressure is dreadfully low. The hight of the feeder water tank (50 gallons) is approximately 5 feet above the top of the hot water cylinder. Would a circulating pump fitted between the hot water outlet of the cylinder and the faucets improve matters?
