| Posted by hj on August 13, 19100 at 23:35:47: | |
| In response to Re: water heater thermostat reset | |
Your lower element may be burned out and/or the lower thermostat may be stuck so it does not turn off. A bad element can damage the thermostat, so you have to check everything. : I very often (almost every other day) have to reset the top thermostat in order to have hot water. I have replaced the thermostat but the same problem occurs. I have plenty of hot water when it is operating, but the reset button constantly is tripping off. What could be the problem?
| There are none. |
