water feed hose from valve to toilet
Posted by bruce on August 13, 19100 at 23:15:30:
I replace the pump, or water regulator in my toilet tank that was leaking and of course I move around the water supply that was a solid tube with a pressure fitting and it started to leak on completion. I went to my nearest big home store and purchase a flexible metal hose with a pressure fitting- that's how the straight pipe was installed, my question is " how much should I tighten this pressure fitting hose" I hand tighten it and then used the wrench on it not more than 1 turn. It's not leaking but I am still nervous. The instructions on the tank regulator told me no to over tighen,put I have none for the water hose to the water valve. Thanks Bruce
Replies to this post
There are none. |
