| Posted by cecil gates on August 13, 19100 at 14:42:45: | |
iam installing a new boiler & hotwater heater(electric). i had a suggestion of installing a small circulating pump on the line between the boiler, and the heater(with shut off valves). as the lines run overheat between them which size pump do i need and in which line should it be installed? |
