| Posted by hj on August 12, 19100 at 00:01:08: | |
| In response to Re: Shower Pan Liner | |
Once water reaches the level of the dam nails through the liner are going to be the least of your problems. : I'm about to install a Shower Plan Liner.. I pretty much know everything I need to know. Except. For dealing with the Dam. Once the Liner is place up and over the dam. Does the Mud Base then extend up and over the dam as well? If so how do I form this.. At first I was going just use backer board, but the would require nailing through the liner, which is bad.. : My Shower pan will have a Dam on two sides.. One side will be a Glassblock wall and the other will be the entrance..
| There are none. |
