Re: Toilet flapper won't stay up long enough to give a good flush
Posted by hj on September 19, 1998 at 19:32:12:
In response to Re: Toilet flapper won't stay up long enough to give a good flush
Terry:
This is one situation when the belt and suspender redundancy works against the user. It come across this fairly often when they want to use both methods.
: Most of the flappers sold are designed to fit either around the overflow tube or clip onto the "ears" at the bottom of the overflow tube. If the ears are to be used, then the portion of the flapper that would fit around the tube would be cut off and thrown away.
: Terry
Replies to this post
There are none.
