| Posted by hj on September 19, 1998 at 19:28:14: | |
| In response to Re: water pressure | |
Before you do anything, place the softener into the bypass mode. I think you will find that the pressure is fine when the softener is bypassed. A larger pipe only helps if you are using more water than the pipe can supply, and one or two faucets willnot overpower a 3/4" pipe. : Pressure and supply are fine until you-- (example) You are taking a shower(supply & pressure fine) a
| There are none. |
