Re: water heater
Posted by hj on September 19, 1998 at 19:24:26:
In response to Re: water heater
The only difference between low, medium, and high is how long the burner operates. You have a ventilation problem and after the heater operates for a while, the carbon monoxide gas from the heater is putting itself out.
Give the heater area more air, and get a carbon monoxide detector for the house.
: we have a two year old gas water heater. the pilot light goes out when set on med. or high. if set on low it it fine but the water isnt;t hot enough. we replace the coupling and we still have the same problem. what elese could be causeing this.
: thank you,
: peggy willer
Replies to this post
There are none.
