| Posted by Suzy on August 05, 19100 at 23:10:44: | |
| In response to Re: Clawfoot Tub | |
Thanks for the response. Under the cement board is diagonal 7/8" rough sawn oak tongue and groove on top of 16 1/2" spaced floor joists. Will that be OK? What about the round ball of the feet pressing on a tiny spot of tile? Thanks, Suzy : What is under the cement board? If it is just the pine subfloor, then it and the cement board will flex and cause the tile rout to crack. If this is the case in your installation, you may have to install additional bracing under the floor to restore stability to it. : : We are installing an antique clawfoot tub that has ball feet. The floor is 1" hexagon tiles. Will the tub crack the tiles? The tiles are installed on 1/2" cement board. Do we have to put anything under the feet? There used to be a clawfoot tub in the house originally, but it was installed on an oak floor (you could see the dents). The oak floor was damaged from the previous owner so we had to take it up. Any advise would be great. Thanks.
| There are none. |
