| Posted by hj on August 05, 19100 at 09:46:14: | |
| In response to Re: Removing a radiator permanately | |
It depends on whether it is hot water or steam, and, if hot water, whether it is a one or two pipe system. If it is a one pipe hot water system, then you have to reconnect the two openings to maintain the proper water flow. With other systems you can just cap off the pipes. : We are currently decorating and would like to remove a radiator permanately. Please advise. : Many thanks
| There are none. |
