| Posted by hj on August 05, 19100 at 00:23:48: | |
| In response to Re: Vacuum Breaker repair kit for Zurn toilet flushometer | |
If you are just changing the vacuum breaker, then there is only one version, and Zurn has copied the Sloan design. : Hello, I was wondering if I could use a Sloan vacuum breaker kit in a Zurn 3.5 gallon toilet flushometer, or does Zurn have its own kit? This is for one of the toilets in my brother inlaw's pizza parlor, so I was wondering what is the model number of the kit that I can use in this valve? Will the new kits work with the 3.5 gallon valves, or will it cause the valve to turn off early? Thanks in advance for your help.
| There are none. |
