Best Ejector Pumps?
Posted by Dean Smith on August 04, 19100 at 16:29:40:
I'm considering changing my pump when I open up the pit to check out a problem. My question is, which pump is best? My criteria are 1) DEPENDABILITY, 2) QUIETNESS, 3) EFFECTIVENESS. I believe a Hydromatic is in there now (it has a two-sensor POWERED switch), but it seems kinda noisy. I've always liked Zoeller sump pumps, and their big ejector looks like a BRUTE, but I'm unsure if the float switch is super-dependable in an ejector situation. Apparantly you can get it WITHOUT a float switch-is there a better switch (Hydromatic's ?) that can be used instead? Any top-notch pump brands I'm overlooking?
Replies to this post
There are none.
