Re: Water Softener Blockage
Posted by Louise on August 04, 19100 at 09:39:11:
In response to Re: Water Softener Blockage
: I have a Culligan Mark 89 water softener. It has recently stopped producing soft water. Upon checking inside the brine tank,the water has risen up to the float valve shutoff level. When I run it through a recharge cycle, nothing occurs when it should be backwashing water from the brine tank. The only sounds I hear are the rapid rinse and brine tank refilling cycles. So, there must be a blockage within the brine tank. What could it be the problem and how do I correct it?
Replies to this post
There are none. |
