Re: Hooking up to municipal sewer system
Posted by hj on August 03, 19100 at 00:45:40:
In response to Re: Hooking up to municipal sewer system
If their idea of a "forced main" is the same as mine, then you will not hook up to it without a good pump and some very sophisticated control devices. But they may mean that it flows to a resevoir and is then pumped out by a municipal pump through a high pressure waste line. In that case, you need a local contractor to detemine the sewer depth and the method of connecting to the main.
: I am trying to find out what it takes to hook up to the municipal sewer line. I am told that it is a forced main. What type of equipment will I need to make this work? I have a four bedroom home with an on-site sysem, a 1000 gal septic tank and the run from the septic tank to the sewer main will be approx 200'.
: Also would you have a ball park figure (cost) for the equipment needed.
: Any help will be appreciated
: Thanks
: E
Replies to this post
There are none.
