| Posted by Jack on August 02, 19100 at 17:42:11: | |
I have a Culligan Mark 89 water softener. It has recently stopped producing soft water. Upon checking inside the brine tank,the water has risen up to the float valve shutoff level. When I run it through a recharge cycle, nothing occurs when it should be backwashing water from the brine tank. The only sounds I hear are the rapid rinse and brine tank refilling cycles. So, there must be a blockage within the brine tank. What could it be the problem and how do I correct it? |
