Re: Clogged bathtub drain
Posted by Casman on August 02, 19100 at 14:49:28:
In response to Re: Clogged bathtub drain
Try this. There should be a round metal trim ring around the lever that moves up and down to drain the tub. Remove this and slide out the stopper assembly. Then stuff an old wet rag into the hole, pushing it in to seal off the tube. Then fill the tub partway with hot water and plunge the hell outta it. This almost always works with a decent plunger. Good luck
Replies to this post
There are none. |
