Re: cast iron pipe fittings
Posted by JOHN on August 01, 19100 at 21:51:38:
In response to Re: cast iron pipe fittings
: I have a number of castiron fittings to remove, they are sealed with a rubber fitting. How do I remove the old pipes without damaging the fittings that will have new pipes installed. This is undergroung piping covered with concrete. Can I use rubber tie ins. Any other advice in this area would also be greately appreciated. Thanks and look forward to your reply!
Replies to this post
There are none.
