| Posted by hj on July 29, 19100 at 18:09:50: | |
| In response to Re: laundry or pot scrubber sink | |
Look under Restaurant Equipment in the yellow pages. There should be many dealers in used equipmant that might have what you want. Three hole is going to be more common, but there are also a number of two basin sinks that should work. Due to sanitary requirements, you will normally not find galvanized sinks, and porcelain steel were never made in that configuration. : Hi Terry, I'm trying to find a large two hole sink, like the kind you see in resturants, butcher shops etc. I've found a couple of MFG.
| There are none. |
