| Posted by dick on July 28, 19100 at 10:53:01: | |
| In response to Re: regrouting stall shower | |
grout is a cement based material used between tiles. What you are talking about is caulking. The secret to getting it to hold is removing ALL the old caulk and cleaning thoroughly. Use a putty knife or a sharp knife and scrape between the aluminum and the tile. The stuff you are using is called "Adhesive/Caulk" but it is a very weak adhesive. You have to get it between the aluminum and the tile, not just a bead of stuff covering the edges. make sure everything is completely dry. Work it into the crack with your fingers, go over it several times. make a smooth finish by wetting your finger and going over it one last time. Rub excess off adjacent surfaces with a dry rag. If the aluminum track is not fastened securely, your caulking likely will not last. The aluminum will flex and buckle with temp changes , breaking the seal. I refered to tile several times, but it works the same with a fiberglass shower stall or other materials. : We had a new aluminum enclosure installed for our stall shower about 2 years ago and it is now leaking through the grout around the base. the contractor used G E Silicone grout.
| There are none. |
