Re: Do you install greenboard over the top lip of a tub?
Posted by Dean Smith on July 26, 19100 at 15:08:59:
In response to Re: Do you install greenboard over the top lip of a tub?
: I would like to replace my tub and wondered if I am supposed to install the new greenboard over the lip of the tub or just up to it? I am going to install a fiberglass 3 piece surround as well. Thanks for the help. Yes, the board should overlap the lip, but it should NOT go all the way down to the top of the tub. I used a piece of 1/4" lath as a spacer (removing it once board is secured). You should really look into using cement board (Durock or Wonderboard) or DenShield instead of greenboard. Both options do a much better job and are not much more expensive.
Replies to this post
There are none. |
