Re: water pressure is WEAK
Posted by hj on July 26, 19100 at 09:05:56:
In response to Re: water pressure is WEAK
Your water pressure problem is not the reason for the toilets not flushing, since toilets create their own pressure from the water in the tank. The showers probably have water saver heads on them and that is all the water they are allowed to deliver. The faucets also probably have low flow aerators for the same reason, and with the same results.
: Just moved into a 9 yr. old house with low water pressure throughout. I'm use to a FIREHOSE type shower and cannot achieve that in my new house. The toilets threaten to overflow just from the pressure not being strong enough to FLUSH THE STUFF. Kitchen sink is the same.The pressure is not PATHETIC but, I would LOVE some advice.
Replies to this post
