| Posted by Pumps up to hights on July 25, 19100 at 15:30:23: | |
| In response to Re: need advice | |
: The distance is immaterial as long as the rise is not greater than the pump's lift capacity. : : Will the sewage ejector pumps.....pump the waste 70 feet away into an existing sewer system. There will be a small incline to this new system also. Yes, the sewage ejector pump is designed to lift the waste water as well as pump it away. The ejector pump sits in a receiving tank that gets maybe five to ten gallons full (more in commercial installations) when a float rises and starts the pump. It grinds the material small enough to get pumped up to the elevation that the pump is rated for. Yes it can pump up the small incline. |
| There are none. |
