Re: Low HOT water preasure from every fauset in the house.
Posted by murphyplumbing.com on July 23, 19100 at 18:37:08:
In response to Re: Low HOT water preasure from every fauset in the house.
:open some of the aerators on your faucets, do you have small white particles in them? some water heaters have defective dip tubes that fall apart into little pieces. If you do, then replace the dip tube in the water heater.
I hooked up a garden hose to the water heater hoping I could drain of any hard water deposits that may be causing the problem, but the only thing that came out was water no deposits. Is this the problem? What should I do next.
Replies to this post
There are none.
