| Posted by finley on July 22, 19100 at 13:23:58: | |
| In response to Re: How to install drain on stall shower base | |
: : Purchased a base, came with a drain, but no instructions. The drain has black rubber gasket. Does this gasket go on top or bottom side of base? Thank you very much. : The rubber gasket goes under the shower pan, then the fiber friction washer, then nut. On the top side of the pan, you can use Silicone on the flange of the drain. Terry
| There are none. |
