| Posted by murphyplumbing.com on July 22, 19100 at 12:03:22: | |
| In response to Re: Hot Water Heater Leak | |
:most of the time around here if you have an electric water heater you are in the country and on a well or a local water co. and 8-10 years is normal for a tank to leak, time to replace it. I have a Bradford White 80 gal Electric Hot Water Heater (model M-I-80R5SS-12). It was installed with : Under the heater there is a circular cutout that is about 4-5 inches in diameter. Water is leaking : Any ideas on what may be causing it and what it would cost to replace or fix it ? : Thanks.
| There are none. |
