Re: low hot water pressure
Posted by Wayne on July 21, 19100 at 08:23:41:
In response to Re: low hot water pressure
: : I have a moen faucet in my shower.I turn it on counterclockwise.I have plenty of cold water pressure but when I start to add the hot water the pressure decreases.When the water is finally warm enough to shower in there is not enough pressure to activate the shower.The house is hooked up to a well with a max. pressure of 50 p.s.i. and a low of about 30 p.s.i..I would appreciate any and all suggestions any one might have.Thanks. : I would remove the cartridge to clean and inspect. It sounds like some sort of blockage on the hot side. Either debries in the cartridge, the valve body, or the pipe from the water heater. Terry : Terry,I removed the cartridge and found no blockage and also the pressure in the rest of the house is good.I'm looking for a replacement cartridge but haven't found one yet.Wayne.
Replies to this post
There are none. |
