| Posted by brian on July 20, 19100 at 18:05:08: | |
| In response to Re: Water Heater Recirc. Pump | |
: I'm plumbing a new house, and I want to use two 40-gallon water heaters. I intend to use three : recirc. pumps to keep hot water at the three most distant bathrooms. (They're each plumbed back : to the same place - sort of a manifold configuration.) Should I plumb the water heaters in parallel, : in order to get the best flow, or in series? Also, do you have any suggestions on plumbing the : three recirc. pumps into the same hot water heater? (I assume I can just build a manifold, and : I'll probably have to use anti-backflow devices at each pump and at the cold water inlet to the water : heaters...) : Thanks!
