| Posted by More on July 20, 19100 at 15:42:09: | |
| In response to Re: Was locating pipes, now another idea | |
: Thanks to all who answered my call for help in locating pipes in a slab floor. Before I start digging ,I found this "thing" called a Drainosaur. This device attaches to the drain on the laundry tub and pumps the water to another location for drainage. In my situation I'd be pumping the water up into the attic and back over to the original laundry room tub and drain line. The distance between the rooms is about 15 feet and the height of the attic is about 10 feet. The pump is rated for 21 feet of lift. Does anyone have any opinions on using this method?? Do you think it would be approved by a city building dept? Should the drain line be attached to the existing line or could it just empty into the existing laundry tub? : Thanks again : Fred |
| There are none. |
