Re: water leak/ complete idiot
Posted by 22 bullet holes on July 20, 19100 at 13:49:37:
In response to Re: water leak/ complete idiot
: I had a early evening call from a customer regarding a water leak in his attic. He was not home when I arrived, but the ladder was in the garage and the scuttle hole was open. I noticed that the ceiling was completely drenched and all the drywall screws were visible. I turned the water on slightly and then went up there to check the leak. In Scottsdale, we have home fire sprinkler systems. Usually they are installed with CPVC pipe, but this one used copper. The leak was in a copper fire line, but it appeared to have been made with a 1/4" drill from underneath it, since the exit hole on top was burred out. I could not see how a drill could have been used on it because there was only about 4 inches between it and the sheetrock ceiling. Anyway, by this time the owner came home and I asked if anyone had been working in the attic that afternoon, and he implied that there had been someone up there. He then called his father to tell him what had happened, and then the father asked to speak to me. When I told him about the hole drilled in the pipe, he asked me, "Could it have been a .22 bullet?". Lights flashed in my head, and I said, "Yes." I then discussed the situation with the customer and he told me that he thought he had heard someone in the attic or on the roof, so he used his .22 automatic and shot holes in the ceiling, and by implication, the roof. Those spots I thought were drywall screws were the .22 holes, about 20 of them. three shots went through the air conditioner and at least one was directly beneath the coil. And one had penetrated the fire line almost perfectly in the center of it. I was then glad that I was not in the attic when he returned home. Are you going to consider making a bid on the repair of the air conditioner on the roof utilizing the new KEVLAR material personnel protection roof kneeler pad?
