| Posted by dick on July 17, 19100 at 12:52:57: | |
| In response to Re: install pcv for sink | |
: I put in a new sink and vanity, the problem is the tail piece coming down out of the sink is metal and I want to install plastic pcv plumbing down to the stub out 11/2 in the floor. I bought 1 1/4 inch kit to hook up to drain but I still get leaks coming out of tail piece. The 1 1/4 inch screws on tight to tail piece but I still get leaks there, plus get leaks at the other two nut joints even though I cinch them up hand tight. : Want to know how I can hook up this pcv to metal tail piece down to floor stub out without and leaks. : Please help!!!!! Am very desperate! The 1 1/4 tailpiece is the same od as pvc so pvc connector should fit and seal. do you have seals in the connectors? a pvc slip connection has 3 pieces, 1.a pipe or trap or other pvc fitting with a male thread on the end, and an id that will slip loosely over the 1 1/4 tailpiece 2. a nut with a female thread, and an id that again slips loosely over the 1 1/4 tailpiece. 3. A plastic seal ring made out of softer plastic. has an id that just barely slips over the 1 1/4 tailpiece. it is tapered so that the nut forces it down into the mating piece and squeezing it into the 1 1/4 tailpiece. |
| There are none. |
