Re: bad leak from tiolet pipe
Posted by dick on July 17, 19100 at 12:38:07:
In response to Re: bad leak from tiolet pipe
: what are some of the causes for a bad leak after flushing the tiolet. The water leaks heavy and fast. Is it the seal or a clog. How would I fix it without causing water damage. And could it be that the septic tank might be full. How could I tell if it is?
If the toilet flushes ok, then your pipes are clear and the septic tank is ok.
as for the leak??? where does it leak from??
between the toilet and floor... pull the toilet, check for damage or anything that doesn't look right, replace the wax ring.
between the tank and bowl.... pull the tank and replace the spud seal... if it's real old... replace the whole standpipe and flapper assembly. Check for cracks or other damage while you have the tank off.
Replies to this post
There are none.
