| Posted by hj on July 17, 19100 at 09:59:05: | |
| In response to Re: Vinyl under tub???? | |
What kind of tub is it? If it is a built in tub,then there is usually a considerable amount of construction necessary after the tub is installed but before the room is ready for flooring. If it is a "leg tub", then the vinyl goes down first to eliminate holes where the feet will set. : Vinyl estimator wants to install vinyl under the tub in our completely refurbished bathroom. Is this a good idea or should we install the tub before the vinyl goes down?
| There are none. |
