| Posted by Terry Love on July 17, 19100 at 01:39:30: | |
| In response to Re: bad leak from tiolet pipe | |
: what are some of the causes for a bad leak after flushing the tiolet. The water leaks heavy and fast. Is it the seal or a clog. How would I fix it without causing water damage. And could it be that the septic tank might be full. How could I tell if it is? Could be a bad wax seal, cracked toilet, leaking gasket between tank and bowl. Terry
| There are none. |
