| Posted by hj on July 13, 19100 at 09:38:27: | |
| In response to Re: converting to toilet flange | |
It depends on the drain pipe material. If it is lead, then forget about it. If it is almost any other material then you can create an annular ring around the drain pipe and install a flange of the same material. : hello; : My toilet is secured to the floor via two closet lag bolts, how easy would it be to convert : thanks;
| There are none. |
