Re: water backed up between pipes
Posted by Terry Love on July 12, 19100 at 20:15:28:
In response to Re: water backed up between pipes
: Upon investigating a leak in our wall, I discovered a 1 inch pvc pipe that runs down the wall (inside of the wall) and into a bigger 2 inch pvc pipe. The pipes are not sealed together. It appears to be part of the drainage system. Anyway, the water is backed up and is very slowly overflowing over the top of the 2 inch pipe. In other words, it appears to be plugged! The 2 pipes meet about 6 feet from the ground but I can't tell where the 2 inch pipe goes (only that it goes down). Any suggestions?
I would try snaking the 2" line.
The smaller pipe, may be a condensate drain for air conditioning. Terry
Replies to this post
There are none.
