Re: Replacing a drain line - Need advice
Posted by Wayne Hernandez on July 12, 19100 at 12:03:46:
In response to Re: Replacing a drain line - Need advice
: Charles, replace the bad part that the plumber found mud at and camera the rest of the line to see if there is more damage. If the line is orange burg I suggest to replace entire line. Dale's Plumbing Service LMP I discovered I have orange burg for my drain. I replaced a small section to install a clean out, but the next part goes under a tree. Should I leave the part under the tree alone, or is there a way to get that part out.
Replies to this post
There are none. |
