| Posted by Scott Bryan on July 12, 19100 at 10:24:24: | |
| In response to Re: Shower Valve Parts | |
: : Our shower valve needs new knobs. It has a round knob with "Mixit" engraved. It is the ON/OFF and volume : : control. Behind it is a lever pointing down which adjusts the mixture. The round knob is held on a : : beveled shaft with a center screw. This shaft is concentric and internal to the mixture shaft. The round knob was : : frozen on the shaft and even after multiple applications of penetrent, I broke the knob prying it off. The lock : : screw on the mixture lever is also frozen and it seems I will have to cut the knob off. : : This screw is behind the lever and close to the tile. The purpose of all this is to disassemble the valve : : for lubrication. : : Is MIxit a brand name and, if so, does it still exist and/or are parts available? : Spelled name wrong. Should be "Mixet" Gary, Scott |
| There are none. |
